EVO Rocker Skins and Rock Rails Questions
Old 10-25-2012, 07:16 PM
bbrown626's Avatar
Originally Posted by JE8154
Not quite as beastly as the monster of a jeep above but, I'd definitely recommend getting some sort of a skin. Really completes the look.
Attachment 382385
Your sliders seem to be a tad higher than those above. From the pics on the Off Road Evolution site it looks like the bottom row of fasteners on the rock skins are above the rail, which would make it easy to install them later.
Nice looking rig though! The skins definitely complete the look. At this point I am more concerned with function. I may put the skins on of the boss lady agrees.
Thanks.
Old 10-26-2012, 07:16 AM
Sponsoring Vendor
chris@offroadevolution's Avatar
Originally Posted by MTG
Skins first if you plan to add them. I can't imagine doing it after the rails are on. Plus if you don't do it yourself (which you should), it will be that much more expensive.
Good luck!
Attachment 382482
Attachment 382483
If this guy can do it, Anyone can!
Nice Job Mike
Old 11-05-2012, 05:56 PM
bbrown626's Avatar
Good luck!
Attachment 382482
Attachment 382483
Did you weld your rails on or did you have someone else do it?
Curious how they are aligned. Any feedback on installation of the rails?
Old 11-06-2012, 03:13 AM
rickc309's Avatar
I like the look of the skins, but a concern of mine would be body corrosion from the salt on the roads getting behind them during our winters here in Illinois.
Old 11-06-2012, 04:20 AM
JK Forum Regional Rep
OhhSeven's Avatar
X2! Drilling into the sheet metal is out of the question in this part of the country.
Old 11-06-2012, 07:26 AM
Sponsoring Vendor
you clamp them in place where you want the rock rails, then weld them up...
Old 11-06-2012, 07:52 AM
MTG
MTG's Avatar
I do not weld so I had someone do it while I helped. There isn't much room to misalign them, especially up and down. As Chris said, you just line them up, clamp them down and weld away.
Old 11-21-2012, 06:17 PM
HiHoSilver's Avatar
I am wanting to get these sooooooo bad! Can someone take a straight on side shot of them with a tape measured measuring the top of the rail to the bottom of the door. Right now I have stock rails and want to know how much higher these are going to be.
Thanks in advance!
Sent from my iPhone 5!
Old 05-30-2021, 06:29 PM
Giddy -Up's Avatar
Default Posion Rocker Skins
I want to have the poison rocker skins installed on my gladiator I’m in Southern California anybody have a suggestion how much they charge and where’s a good place to have this installed?
Quick Reply: EVO Rocker Skins and Rock Rails Questions
