Extension on ABS Brake Lines?
Old Sep 25, 2008 | 06:25 PM
Rebel Heart's Avatar
Default Extension on ABS Brake Lines?
I just installed the extended brake lines and was wondering if there is a need for extensions on the abs lines? It seems like they might be a little short. Any comments? Thanks.
Old Sep 26, 2008 | 01:52 AM
aldaman's Avatar
Here's a link to a similar thread...The ABS has plenty of room, just need to adjust them...See below...Hope this helps....
Originally Posted by aldaman
I know JulietKilo did a write-up on adjusting the ABS line a couple of months ago...Below is the link to that thread...Hope this helps...
https://www.jk-forum.com/forums/show...772#post668772
Originally Posted by JulietKilo
SENSOR CABLE ADJUSTMENT
The brake lines are tight before the adjustment and longer brake lines are not installed but I was able to get the sensor cable to have a ton of slack. There was slack in the front of the caliper that can be moved to the rear for longer droops. I have a 4 inch spring and my droop is awesome. I need to measure it but that is another time.
Pull the connectors off the mounts. The will slide right off. Then you can just slide the long grommet down the wire to create room for droop.
Move onto the lower grommet and do the same.
Reinstall them and you will be amazed with the extra slack.
After the adjustment there is plenty of wire for the droop. The brake lines however will need attention eventually. The shocks will determine how much and that will be addressed as soon as I get them.
https://www.jk-forum.com/forums/jk-write-ups-39/get-more-slack-your-brake-sensor-wires-front-end-flex-47613/
Old Oct 31, 2008 | 09:18 PM
HaoleRubicon07's Avatar
thanks for the replies. ive already unhooked the wires from the little metal retainers but they are still a little short. Are the esp wires just regular wires or are they something special?
