Extra lighting - any problems doing this?
Old Mar 13, 2008 | 05:54 AM
HappyCurmudgeon's Avatar
Eternal ***erator
Originally Posted by crusher
Wouldnt this require two relays in series? This is basically what I want, but I cant seem to find a wiring diagram that would make this configuration work? Anyone done it successfully?
Nope, just one relay is all that is required. Run the trigger wire from the toggle switch to your hibeam circuit instead of a constant on 12v source.
Wired as shown below, the relay will only be powered on if:
A. The hibeams are on, and:
B. the toggle switch is on.
If you want the light usable regardless of when the hi's or lows are on, connect the switch to another source, like the running lights for instance.
I strongly recommend that wherever you hook the trigger wire up, it is to a source that shuts off with the key, that way you wont accidentally leave the lights on and drain your battery.
Old Mar 13, 2008 | 06:39 AM
USAF_GroundRat's Avatar
Actually, I believe using one relay will cause voltage to be back fed into the High Beam fuse and turn on your high beams:
You can avoid this by using a 12 volt diode on the path from the High Beam fuse or you can do this with 2 relays:
I posted this before I saw that Happy posted his drawing... but the logic still applies. The note that he had about using an ignition hot circuit is great advice. There are many places in the fuse box under the hood to do this, just whip out the multimeter.
Old Mar 13, 2008 | 07:06 AM
Eternal ***erator
yup, using two sources to the same line would give you issues, that is why i used the highbeam power with an inline switch as the trigger. Seemed like the simplest setup to me and used what i already had in the light kit.
It was that...
or this:
Old Mar 13, 2008 | 07:38 AM
Eternal ***erator
Originally Posted by N2rock
the KC kit comes with instructions on how to tape in to the high beam and use it as the trigger for the relay. So basically the relay will have to have both the KC switch "on", and the high beam "on" in order to trip the relay (at least that is how I understood it). But since I didn't want it wired that way, I didn't bother reading/understanding it.
that's the first schematic i posted.
Old Mar 13, 2008 | 08:56 AM
crusher's Avatar
Since my google products search for thermonuclear particle decay machine did not return any results, i'll have to stick to the battery... for now. Thanks for the info.. i'm gonna order up the KC's as soon as my tax return shows up in my account.
