factory bolt replacement
Old Mar 24, 2013 | 08:20 AM
TheDirtman's Avatar
The northridge kit is very nice hardware, they use a thick washer and one of the nicest bolts I have ever seen.
Old Mar 24, 2013 | 08:55 AM
monstermudder78's Avatar
Originally Posted by bill9274
i found a list. $60-80 is a little step for 12 or 13 bolts. i will go to fastenal or tsc and spend about $10.
Would you mind posting it?
Originally Posted by c4bus
Honestly grade 8 hardware is pretty expensive. Most bolts will be about 2.50, and the nuts will be about 2. So their prices are pretty dead on. You really want to cheap out with key bolts in your suspension? Nothing like having your track bar bolt shear off going 80 down the highway. Is your life only worth the $20 you'll save?
Buying grade 8 bolts is hardly "cheaping out." Northridge may have a nice kit but they surely aren't magic bolts.
Old Mar 26, 2013 | 12:05 PM
bill9274's Avatar
i am an industrial mechanic and worked for cat before both places get all there grade 8 bolts from the same place fastenal. The machines i work on throw out around 1200 diapers a minute and we use fastenal bolts to hold the 300 to 600lb rollers turning at over 3000 rpm together so i am rather confident that the fastenal bolts will be good quality seeing that in the past 17 years i have never seen anything hit the floor because of poor bolt quality. i found a list gave it to the regular fastenal guy at the plant he brought me everything on the list plus a couple extras and a bill for $7.89. i would be happy to buy from northridge if i didnt have access or knowledge on this type stuff. i do have alot to learn about jeeps but alot of really good products get horribly bashed on all forums. the main reason is they are not sponsers so if anyone sees something and starts researching these forums are great but also check outside them to make sure there not just getting bashed because there the wrong name brand.
Old Mar 26, 2013 | 12:17 PM
Maertz's Avatar
I aswell used fastenal. Got my old employee discount and it was about 5 dollars....
