Factory Fogs
Old Sep 26, 2009 | 04:59 AM
CLOTAGAMES's Avatar
Default Factory Fogs
Installed a new Rugged Ridge XHD bumoer last night and moved the factory fogs over to it. Took it out for a ride and the fogs are pointing up way to high. I think I may have mounted them upside down. The housings had small holes in them, so I assumed they were drain holes and mounted them facing down. Any ideas of which is up and down? What size torx to adjust?
Old Sep 26, 2009 | 05:04 AM
Tight_wad's Avatar
Easiest way to say which way, is that the electrical plugs in on the drivers side of the both of the lights. As far as the Torx size, don't know, mine all have the sizes worn off of them. Just use the on that fits.
Hope that helps!
