Factory Limits Torque in 1st and 2nd
Old Oct 7, 2009 | 12:04 PM
  #31
spinlock's Avatar
Originally Posted by tpm152
More than likely it will not go WOT in first or second in order to allow effective use of EGR in the 3.8s. The old 4.0s were nice engines because they didn't need to pass any stringent emissions standards. And as everyone knows the reason they switched the new Jeeps to run the 3.8 is to pass emissions standards.
BTW, they could have probably (if they even tried) passed stringent 50 state emissions with the 5.7L HEMI driveline and possibly improved their CAFE ratings.
Old Oct 7, 2009 | 12:22 PM
  #32
Atl JK's Avatar
The 5.7l "Hemi" is far from a clean running engine. They barely got it to pass emissions by running two spark plugs per cylinder and using speed density programming. Among other things that I can't recall off the top of my head... The '09+ version might be better, I don't know much about it. It also isn't known for its fuel efficiency and would not have made a CAFE improvement.
The now late 4.7l would have been a better choice in both regards.
Old Oct 7, 2009 | 05:38 PM
  #33
Torque Limit's Avatar
Thanks!
JPop, So Cal Tay 12, ronjenx, Foo, GoodysGotaCuda, pearl-drum-man, CJ7nvrstk, dmhines, Atl JK, tpm152, spin lock, and anyone I just missed -
I appreciate that you took the time to respond.
JPop, I take your SC contact as the final word - The torque limiting I feel is not imagined.
Thanks for defining a fix! Sold.
Old Oct 7, 2009 | 06:21 PM
  #34
spinlock's Avatar
It's clean enough to run in CA RAM trucks, but you are right.
My line of thinking more along the lines of the 5.7L which has similar MPG ratings as the 3.5L in the Charger. Sometimes larger engines with more low end torque can provide more or equal fuel efficiency as smaller engines, because they can operate in the lower RPM band.
Old Oct 7, 2009 | 08:50 PM
  #35
Atl JK's Avatar
I defeinitely agree there. I wish a LSx engine bolted in like the Hemis do. I think a fuel efficient V8 would be great.
Hell, my 4.7l WJ got 22 mpg at 80 mph because it had a fuel efficient V8 with good power/weight ratio and a low cruising RPM.
Old Oct 8, 2009 | 03:24 AM
  #36
JPop's Avatar
I still want to get out and test it myself, just a bit busy and will need to wait for the weekend.
Part of these pesky emissions standards are NOx (which comes from high stoichiometric combustion temps, especially before the catalytic converters have a chance to get up to operating temps). One of the easiest ways to keep NOx down is to recirculate exhaust (EGR = exhaust gas recirculation) so that the "fresh" charge going into the cylinders have not only less oxygen available because the exhaust has displaced it (hence you inject less fuel for stoich combustion) but the mixture with all the CO2 and water has a higher specific heat, so you reach even lower peak combustion temps.
The reason why the throttle wouldn't open all the way for effective ERG use is to draw a vacuum in the intake to pull the exhaust gases through the EGR loop and back in the intake.
This is good information and another thing to ponder as to what's actually going through the head of the PCM and what it means for the 3.8. It also makes sense as to why I had a lean problem with headers and stock PCM while also my first programmer, better cylinder evacuation and less EGR. The one thing that doesn't make sense is that throttle position is limited for emissions purposes as SC allows low gear WOT and as a mandate since they were taken over by MSD is that all of their products are 50 state legal and abide by CARB standards.
