Factory Plastic Garbage Mods
Old Jan 23, 2011 | 10:26 AM
Rusman161's Avatar
I just did a writeup on the VDS caps that are on the quadratec site. I don't have the link on my phone, but search for VDS stubby bumper conversion.
Old Jan 23, 2011 | 10:28 AM
JCKnauer22's Avatar
Originally Posted by Edge Hawk
Sup man, where was that pic taken?
that was taken at rausch creek up in PA. this was from last year's topless for tata's run. it's a nice off road park with trails of all levels. there are several forum-related events up there each year. keep an eye on the east coast page for local group rides as well as events like the east coast easter jeep safari, topless for tata's, and if they bring it back from the dead, the JKfest. the park's website is h ttp://www.rauschcreekoffroadpark.org/index.php
hijack over
Old Jan 23, 2011 | 04:25 PM
JCKnauer22's Avatar
They do make end caps for the factory front bumper as well. They are on Quadratec. Just and idea of u don't want to rig something.
while i'm glad there's a simpler option out there, i can't say i'm a fan of either of the makes of end caps currently available. i do like the VDPs better than the RCs, but i'm still not sold on the plastic fasteners or the material. i know the stock bumper isn't much to start with, but how thick/sturdy are these caps? will they take a light hit or a nudge from a rock or tree or some goober in a parking lot? i feel like you'll wind up with broken fasteners or ruined end caps more often than not. kudos to these companies for such ingenuity, but i can't help to feel that something is lacking. i know the home-made version wasn't as easy as these, but it wasn't hard by any means either. it is also stronger and i feel it looks better. best of all, it was FREE aside for the price of some rivets and washers. who doesn't like free?
Old Jan 23, 2011 | 05:39 PM
JeepItm8's Avatar
Check out the "JK Forum" write ups. I know I've seen some postings on this subject.
There was recently a fender trim mod party here in SoCal and from the pics I saw the fender trims were nice looking.
Old Jan 23, 2011 | 05:42 PM
Blendo's Avatar
I'm researching this for my 2011 Rubicon as well.
Some people have used a solder iron/plastic weld to make it 'seamless' Not sure how that would handle an impact tho.
Old Jan 24, 2011 | 08:44 AM
FlyboyX's Avatar
Originally Posted by JCKnauer22
i just went out (windchill of 13°) and snapped a few shots of different angles with my phone. i posted em in an album since there were 14 shots and i didn't want to overload the page for those using phones or slower connections to view the page.
https://www.jk-forum.com/forums/members/jcknauer22-15607-albums-fender-chop-6312/
i'm still not exactly sure what you guys are looking for so if you want to see more just post up or pm me.
i just used a razor knife for the fender themselves. i did it back in the summer so the heat definitely helped by making the plastic softer. i lightly scored a few lines and then chose my favorite one to go with. then i just went along that line a few times until i went all the way through. that provides a much more controlled cut than trying to go all the way through in 1 shot. i pretty much cut it about 1/4" to the inside of the curve. if you're not comfortable freehanding it like i did you can lay some tape down to give yourself a line to follow. for the curve, i used the same approach except this time i took the blade out of the knife and held it in my hand to give myself a bit more control while laying out possible lines. then i did a rough cut on the outside of my line to get it close, then fine tuned it by trimming a bit here and there to make sure it was a nice smooth curve. doing the final touches with the knife is fairly easy, but it took some time and patience to get it exactly where i wanted it.
the rears were much easier to do since all of the cuts were straight. once i was done i decided to angle the ends to give it a more finished look. i also angled the rear portion of the front flares. then i cleaned the edges with some lacquer thinner (acetone or paint thinner can also be used) and applied the door edge trim.
i decided to keep the front liners since i didn't want too much road debris and trail gunk getting into my engine bay. if you hold up the liners it's pretty easy to see where you need to cut. the same goes for the sub structure. you'll see what hangs out there and needs to be trimmed off once you cut the actual fenders. i used a dremel with a cutoff wheel as well as the little reciprocating saw attachment to do the liners/subframe
i left the rears out since there didn't seem to be a clean way to keep them. i will eventually bedline the portions of the body that were left exposed once it warms up.
ok, that was a lot of this so i'm gunna post separately for the bumper. by the way, there are plenty of write-ups with pics on the forum for both the fender and the bumper chop. i used the cumulative information from these threads along with some trial and error to do both of these projects
EDIT: just so you know, i am running a 1" body lift, so the gaps seen in the fenderwells and under the liners won't be as extreme if you decide to chop your fenders
Thanks for putting all of this up, and for posting the pics in your album. It looks really good. I am definitely going to do this. I'lll post pics when I finish.
