Factory Reproductions SRT8 Wheels
http://www.quadratec.com/products/92502_0X01_A_PG.htm
anybody have these? i havent found anybody with them. they look sick on quadratec's jeep. but the backspacing on them is 6.34. so, how would you even go about making them work? if most lifts require wheels with 4.5 or less bs, how could you pull that off? the thickest spacer i can find is only 1.75" so that would still make it 4.59 bs right?
that's on MT 35x12.5x20.
so, anybody got an idea on what they did here? put em on for the picture but not drive it? keep clear of sharp turns? thicker spacer i cant find? some major trimming?
well, I emailed Quadratec about it, and they said
"A 1.5" wheel spacer was used to fit those tires onto that application... With those spacers that would bring your total backspacing to 4.84". Those will be enough to run that wheel and tire combination on your application."
so, that brings up the question, would you run 4.84 when every lift suggests 4.5 or less?
I got 4.84" for her
