Factory wheel Question???
Old Feb 2, 2016 | 04:47 PM
newjkman's Avatar
Default Factory wheel Question???
I have a 2015 JK 2D, and I like the painted 5 spoke aluminum 16" wheels. Could I mount 315/75/16 tires to these wheels, and get good tread wear with an all terrain tire, or is the rim to narrow? What is the minimum wheel spacer I would have to run to have clearance?
Thanks!!!!
Old Feb 2, 2016 | 08:38 PM
Roryslife's Avatar
Thanks!!!!
Yes... you can easily mount 315 ATs on stock wheels.
You could get away with the smallest wheel spacer possible. 1.25" (though you may have to trim studs slightly)
You will also need to get at least a budget boost.
