View Poll Results: Do you prefer hawse or roller winch fairleads? Why?
Hawse
15
57.69%
Roller
11
42.31%
Voters: 26. You may not vote on this poll
Fairleads
I recently went with hawse for looks -- winchdepot.com was happy to sell me a winch with steel cable and a hawse fairlead, so hopefully I'm not going to get into trouble that way.
Worst case, if the cable starts to look bad, I'll replace with synthetic and an aluminum fairlead anyway.
Rollers are huge and heavy. They tend to be the first thing that hits, limiting approach angle....and getting thrashed.
here is one on my old Sammi:
They weigh about 12 lbs vs. less than 1 lb. for the alum hawse.
plus the alum one are bling.
For Steel cable I would still run a roller though. A steel hawse is hard on the steel cable.
thats why you run chaff guards like the black ones on here:
Just go to any decent outdoor/climbing place and get 1" tubular nylon in 3-4' lengths and slip it over the line before you put it on the winch. And when you see that the line is going to rub against stuff you slide the guard there to take the abuse.
I also carry 2' lengths of old 3" fire hose and carpet remnant squares for the same thing.
The carpet squares also kick ass because not only do they work as a chaff guard but it gives you a dry place to sit on while working on repairs
yes, it would have. steel fairleads have a rough texture to them and tear up synthetic line. Although synthetic line is as "strong/stronger" than steel it still has the abrasion resistance of "rope" and you should protect it from that.
