fender rubbing
Old Oct 15, 2008 | 10:49 AM
mudy 07 rubicon's Avatar
I heard that the 2 inch body lift causes wayyyy too much roll when going around turns. Also, I agree with you about the look of aftermarket fenders but if i had to pick one..itd be the bushwacker pocker style ones..although they dont give THAT much more clearance for flexing.
Old Oct 15, 2008 | 11:54 AM
motorhead0320's Avatar
this is how i fixed my problem.
https://www.jk-forum.com/forums/jk-show-tell-33/trimmed-cut-56251/
Old Oct 20, 2008 | 08:29 PM
RubiJK's Avatar
to prevent the rubbing that you are experiencing now. by the look of your pic, i doubt that a body lift alone will fix your problem. of course, you could always add coil spacers or even taller coils but then, you should still add bumpstop extensions to accomodate them. bumpstop extensions exist to help prevent the over compression of your coils. sure you can get more stuff without them but you may also end up with a lopside standing jeep. eitherway, it's your jeep
Hey WOL, how could this lead to a lopsided Jeep? Is it because the coil would over-compress and then not return back to its original height?
