The Final Seat Belt Solution
Old Jan 2, 2008 | 10:00 PM
aggiejeep's Avatar
Default The Final Seat Belt Solution
so i have an 07 an my riders hate getting in the backseat via passenger side and i was looking at my jeep and figured it out
THE ULTIMATE FIX
the ancor point for the end of the seat belt is connected by a bolt (torx of course) in a plate and that plate is held on by a THIN 1/8-1/4 in piece of steel
THE PLAN
i'm going to cut that strip and undo the bolt and then bolt it down to the bottom of the floor and when i can weld in on. i asked a friend of mine who does safety rating for trucks said that bolted it would work with the right renforcement and welding it would make it unmovable. so in the morining i will do it once i figure out where in the floor would be best to drill and bolt though.
as soon as i am done i will take pics and post a write up in the write up section
wish me luck
Old Jan 2, 2008 | 10:40 PM
aggiejeep's Avatar
ok quick update i am also going to use a 6in L bracket to return the end of the seat belt to it origle postion
Old Jan 2, 2008 | 10:43 PM
Rubimon's Avatar
just check out a TJ, they already had it figured out and then must have forgotten.
Old Jan 2, 2008 | 10:57 PM
aggiejeep's Avatar
i cant seem to find pics on google
Old Jan 2, 2008 | 11:06 PM
Rubimon's Avatar
me either, but my son has one. Everything is connected to the pillar so when you fold the seat forward nothing impedes your entry into the back. They are so easy to get into compared to the JK
Old Jan 2, 2008 | 11:13 PM
aggiejeep's Avatar
well i went outside (f'ing cold for tx) and took a look under my jeep and the only place to drill in would still, once mounted and hae 6 in bar going straight up will give the riders in the back a hard time getting in, a hell of alot easyer but still kinda hard
now i'm re thinking of maybe connected to the seat bracket near the back
Old Jan 2, 2008 | 11:31 PM
Rubimon's Avatar
doesn't show the seat belt but shows the lack of it
Old Jan 3, 2008 | 12:20 AM
aggiejeep's Avatar
ok i cant get the gears in my head to stop so i can sleep, i'm going to go try and figure this out
Old Jan 3, 2008 | 12:31 AM
aggiejeep's Avatar
Default wow cant believe it changed this quick
ok so i just saw a pic of the way the 08s have fix this and basicly same idea i had just mounted the bracket under the retracktor reel on the pillar, time to go freeze and look again
Old Jan 3, 2008 | 12:44 AM
aggiejeep's Avatar
ok so i went out and look and the 07s have the same hole under the seat belt so its going to be a really cheap mod. i also made a discovery about where the seat belt attachs to the seat, its only one bolt so nothing to cut.
i will be going to the my local parts guy tomorrow to see if i can get the bracket from them (most likely giving up my first born to get it) unless the one i ordered is cheaper
