Finally made my decision and went to Teraflex monster control arms!
I am using RE 3.5" coil spring lift and 1" BL right now, in fact, my jeep runs a little bit floats with ruuning the 37" tires right now. Therefore, I think it is time to put on some new arms to adjust my axle and caster.
The teraflex CAs in quadratec.com are currently back ordered; I just got this bad news today, however, do you know any other dealers may have the full set of TeraFlex Monster Control arms in stock?
Thanks for the info! Do you mean the bolt use for the CA? Do I have to cut it once the bolt installed?
Yeah it does, but the new arms come with the bolt you'll need.
Yeah you reuse all the factory bolts except for the one you have to cut off. It'll make sense when you get them. Crawl under your Jeep and you can see the passenger side front upper bolt that needs to be cut cause of the exhaust.
