Fixed Death Wobble!!!!
I am glad you resolved your DW!
However, the bracket you installed corrected the suspension/steering geometry to eliminate classic bumpsteer.
I would still check still every joint and bushing (even if it requires disassembly) to ensure they are not faulty.
I don't have any pictures of the work in progress, but i am more than willing to help you out with designing one. However, I think the only reason i had to do this modification was because of the ProRock Axles. If you have the stock JK axles, PSC has a bracket setup for the stock axle that you don't have to fabricate anything.
What axles do you have?
thanks man, i have a similar problem with my rig. the thin factory bracket wore out, the hole for the bolt to go through became larger and death wobble has insued. i'm stealing your bracket idea for mine!
