Fixed Jeep Pulling to the Left After Tire Change
Old Apr 27, 2013 | 12:24 AM
kjeeper10's Avatar
Vet Army
Originally Posted by TripleBJK
Anyone know the stock ride height of front from the ground to the bottom of stock fender?
Front middle of wheel it's around 201/4 stock.
OP- are you running a HD steering stabilizer?
Old Apr 27, 2013 | 12:27 AM
kjeeper10's Avatar
Vet Army
I have teraflex lowers but a 3.5-4" lift. They are set 2 turns from the shortest setting. I took my measurements of my pinion flange (2 degrees) = 4.0 caster.
Do you know your alignment specs? With the stock driveshaft you can get away with a little more caster. I wouldn't push it though because the angle of the driveshaft is increased.!
Edit: did you install using the un-equal lengths side to side ?
Not every jeep responds well to this and can cause your problem.
For reference, this is with my arms at equal lengths side to side.
Old Apr 27, 2013 | 12:36 AM
DadsCJ's Avatar
That is stock.
