Flighty sterring with new wheels
Old Feb 12, 2012 | 11:27 AM
duckhunter's Avatar
Default Flighty sterring with new wheels
I'm in a confusing situation. I recently put a OME HD lift on my 2010 Jeep and I ran stock 17 inch wheels with 35 inch tires and a 1.5 inch wheel spacer, until my new wheels came in.
The handling was the same as stock until I put on my new wheels. The new wheels are 17x9 with -12 offset. And as soon as I drove it, it pulled hard to the right and jerked around
turns going left, to a point to where I felt like I would lose control. I got it aligned and it drives fine in a straight line but has sensitive steering, and still flighty going around left hand
turns and pulls right. The air pressure in the tires are the same when I had stock wheels. We also measured and found that the tires stuck out the same on both set ups (stock
wheels and wheel spacers vs. -12 offset). My question is, why did my handling go down the drain when I changed wheels only, but still had the same air pressure and backspacing?
HELP!!!
Old Feb 12, 2012 | 11:33 AM
blockrockin's Avatar
how did you balance the wheels/tires ? im guessing you checked to make sure all the lug nuts are tight ?
Old Feb 12, 2012 | 11:37 AM
duckhunter's Avatar
They were balanced at the 4x4 shop with weights stuck on the inside of the wheel.
Old Feb 12, 2012 | 11:38 AM
mkjeep's Avatar
What tire pressure are you running? You may need to lower it. The way tires are now on a 9in rim is different from the stockers 7 in width. There should be more contact with the road but not necessarily the same pressure in the tires as with the stock rim. Play with the pressure.
Old Feb 12, 2012 | 11:43 AM
duckhunter's Avatar
Right now its at 29. I might just have to get an adjustable trackbar and lower control arms.
Old Feb 12, 2012 | 11:44 AM
mkjeep's Avatar
Yeah, you should with that lift.
Old Feb 12, 2012 | 11:54 AM
i agree.. that will give you more adjustability to dial everything in . i think you would be much happier if you did that.
Old Feb 12, 2012 | 11:58 AM
duckhunter's Avatar
That's what I was thinking too. Is there any particular brand that is better than the other?
Old Feb 12, 2012 | 12:04 PM
AK4Dave's Avatar
But still play with the tire pressure in the meantime.......
Old Feb 12, 2012 | 12:16 PM
duckhunter's Avatar
How low is too low for the air pressure?
