Floppy axle
Old Jun 23, 2015 | 09:12 PM
Vladimer's Avatar
Default Floppy axle
Hey guys,
Seems if its not one thing its another.
The last time I went over everything was probably a month or so ago so chasing down a vibe. Also changed out the axle seals maybe 1-1.5 months ago. I had my tires balanced today and the tire guy pointed out my front passenger tire is all floppy and figures my axle is broken.
I took a peak at it and I really doubt the axle is broken as it would be making an awful noise while driving and wouldn't work in much of any capacity (right?). Is this just a unit bearing that is bad causing this play? It is a lot of play which has be a bit worried it might be something else.
https://youtu.be/YcZWPo9ltEU
Old Jun 23, 2015 | 09:54 PM
Albino Lizard's Avatar
Originally Posted by Vladimer
Hey guys,
Probably the unit bearing as you mentioned. I don't think a ball joint can be that bad.
Old Jun 24, 2015 | 01:53 AM
ronjenx's Avatar
Unit bearing is bad. Take the wheel/tire off to confirm.
I'm surprised you haven't gotten any ABS warning lights.
Old Jun 24, 2015 | 08:17 AM
Vladimer's Avatar
You know what... now that you mention it. Last weekend we were out for 3 days and my traction control light came on, the skiding looking one. Figured it was the steering wheel or a wheel speed sensor. Tried straightening the wheel which already looked straight but it didn't go away so figured just a buggered wire and was going to get to it after this week. Its still shining.
On the way home though my ABS light randomly turned on 3 times, shined for maybe a couple minutes and then turned off again. I drove the Jeep a couple times this week and no abs light again. Sounds like those woes might go away. Nice!
