Fox 2.0 Shock Lengths
Old Apr 13, 2015 | 07:33 AM
firejeep508's Avatar
Default Fox 2.0 Shock Lengths
I'm researching shocks for my JKUR and am hoping someone here can help me answer a question.
I found the length specifications for the Fox shocks based on the Fox part numbers. I'm hoping someone can relate the Fox part numbers to the shocks offered with the Teraflex and/or BDS valving. I'm thinking I want to get the softer valving offered, but don't know which version to buy. I hate buying shocks based on a description like "Good for 2.5-4 inches of lift." I have my measurements and want to ensure I'm getting the right shocks for my application.
Thanks!
Old Apr 13, 2015 | 07:40 AM
DunnyBunny's Avatar
JK-Forum Ambassador
What are the measurements you have?
Old Apr 13, 2015 | 08:26 AM
JE8154's Avatar
Originally Posted by firejeep508
I'm researching shocks for my JKUR and am hoping someone here can help me answer a question. I found the length specifications for the Fox shocks based on the Fox part numbers. I'm hoping someone can relate the Fox part numbers to the shocks offered with the Teraflex and/or BDS valving. I'm thinking I want to get the softer valving offered, but don't know which version to buy. I hate buying shocks based on a description like "Good for 2.5-4 inches of lift." I have my measurements and want to ensure I'm getting the right shocks for my application. Thanks!
Call them or a distributor. If you have measurements they should be able to match them up and give you advice on which calving will be better for you.
Old Apr 14, 2015 | 06:18 PM
Post
I was able to get the measurements for the Teraflex versions of the Fox 2.0 Reservoir Shocks. I got what I need, but wanted to post it here for the next time somebody else is looking for this information:
[table="width: 500, class: grid"]
[tr]
[td]Part Number[/td]
[td]Description[/td]
[td]Compressed[/td]
[td]Extended[/td]
[td]Travel[/td]
[/tr]
[tr]
[td]1982820[/td]
[td]Front, 2.5-4" Lift[/td]
[td]15.50"[/td]
[td]26"[/td]
[td]10.5"[/td]
[/tr]
[tr]
[td]1982819[/td]
[td]Rear, 2.5-4" Lift[/td]
[td]16.45"[/td]
[td]27.65"[/td]
[td]11.2"[/td]
[/tr]
[tr]
[td]1982865[/td]
[td]Front, 5-6" Lift[/td]
[td]17.5"[/td]
[td]29.9"[/td]
[td]12.4"[/td]
[/tr]
[tr]
[td]1982864[/td]
[td]Rear, 5-6" Lift[/td]
[td]17.85"[/td]
[td]29.95"[/td]
[td]12.1"[/td]
[/tr]
[/table]
Hope this helps someone!!
Old Apr 15, 2015 | 03:49 AM
Paul Woodcock's Avatar
Hi Guys
Have a look here:
http://www.ridefox.com/dl/truck/fox-...2015-lores.pdf
At the end are all the measurements.
Regards
Paul
Old Apr 15, 2015 | 10:27 AM
Originally Posted by Paul Wood****
Hi Guys
Have a look here:
Regards
Paul
I was there long before I started this thread. That is a great source of information on the Fox parts, but the data on the Teraflex version of the Fox shocks is not in that document.
I had assumed that the Teraflex versions would actually match one of the Fox versions in dimensions and just be pressured/valved differently, but I was wrong. The Teraflex versions are entirely their own specifications, both in valving and in size. That's why I came back and posted the data on Teraflex shocks, figuring that someone would be looking for the specifications in the future at some point.
Old Apr 15, 2015 | 11:16 AM
Hi
Sorry, i didn't read your post properly....... missed the bit about Teraflex version.
Regards
Paul
Old Apr 15, 2015 | 11:23 AM
Hi
Regards
Paul
No need to apologize. Both sets of data will be useful to someone that uses the search function in the future.
Old Dec 5, 2017 | 05:56 PM
CJ7nvrstk's Avatar
Vet Army
Bumping this thread, what are the thought now of those running this shock?
Old Dec 7, 2017 | 08:55 AM
Ajkaz's Avatar
I run the BDS Valved Fox. They are the shocks Metalcloak uses with their fox lifts. Great shock paired with the MC springs, soft enough valving the combo yields a nice ride on and off road.
Running 37's, PSC Fenders & 2.75" bumpstop up front and 3.125" in the rear i use all but 1/4" of the shock travel on all 4 with no rubbing.
Call MC for the expanded and collapsed lengths as they use the same shock for both 2.5" & 3.5" kits.
