Fox ATS install woes
Jayvs, I did try the middle two holes and neither of them allowed the tr to clear the ss. Both hit by a smudge when at full right turn. Enough that it would push up the ss and cause stress on the tr mount. Funny as I think it would be fine if I had a 1/8th of an inch or a 1/4 inch more room.
Hey guys same here.i have a rock crawler drag link, both teraflex and synergy stressing stabilizer relocation brackets don't work. They hit the RC drag link. Go to jeep swag. Com they have a relocation bracket that works with the rock crawler drag link. This is probably why Rockcrawler redesigned their new and improved draglink.
So I have 2011 Rubicon with a Rock Krawler 3.5 lift now for almost 2 years. My stock steering stabilizer has seen better days so I decided to upgrade to the Fox ATS. The RK trackball relocation brackets holes are to low to install this in the correct spot. When I use either of the two holes in the middle when i turn my wheel all the way right the tierod hit the bottom of the shock and pushes it up just slightly. Slightly enough that I don't fee I can install it in this location. I am running the stock tierod as it hasten failed yet. Will an upgrade push the tierod forward enough to prevent this issue? Does anyone have the RK3.5 Max Travel and the Fox ATS SS? For now I have it mounted in the stock position, it will do for now but not when wheeling.
Attachment 584370
Attachment 584371
Any help or pointers is appreciated.
Attachment 584370
Attachment 584371
Edit: Re-reading your post, I should mention I did the drag link flip as well... so that might of gave me the room to start.
Paws,
So, I laid a Strait-line (laser level) across the tr to find center of the rod for these measurements. Far from scientific of course, but likely close enough to answer the differences in stock vs Synergy.
The Synergy tr from center of the tr end to center of the tr is 1 5/8" and for stock is 1 1/4". (How far forward tr is from tr ends, center to center.)
Synergy, from bottom of knuckle where the tr end mounts to center of tr is 1 1/8". I would measure the same place on yours for a more accurate measure since my stock tr is laying on the floor but I measured from the lower evidence mark on the tr end shaft to center of rod and it was 1".
So it would seem with these wag measurements, that with the Synergy tr you would yield 1/2" more forward and 1/8" lower tr mounting point for the ats.
Not sure how serious you wheel or your type of terrain but the Synergy tr is a good investment over stock, especially if you wait for a 10% off opportunity. Note that a 4 1/2" wheel bs and 4 3/4" at most is recommended however.
Regarding previous comments on draglink interference, mine has never hit the top of the ATS. I have an old dl with a flip, ymmv.
So I have 2011 Rubicon with a Rock Krawler 3.5 lift now for almost 2 years. My stock steering stabilizer has seen better days so I decided to upgrade to the Fox ATS. The RK trackball relocation brackets holes are to low to install this in the correct spot. When I use either of the two holes in the middle when i turn my wheel all the way right the tierod hits the bottom of the shock and pushes it up just slightly. Slightly enough that I don't feel I can install it in this location. I am running the stock tierod as it hasn't failed yet. Will an upgrade push the tierod forward enough to prevent this issue? Does anyone have the RK3.5 Max Travel and the Fox ATS SS? For now I have it mounted in the stock position, it will do for now but not when wheeling. Any help or pointers is appreciated.
