Fox ATS steering stabilizer
Old Feb 7, 2014 | 07:17 PM
rubi08unlimited's Avatar
Default Fox ATS steering stabilizer
What relocation bracket are you running with this and do you have a pic installed?
Old Feb 7, 2014 | 08:49 PM
SpicedCrusher's Avatar
You don't need a relocation bracket with this SS
Old Feb 7, 2014 | 10:05 PM
I'd feel more comfortable having it moves out away from the drag link so i'm looking for something that moves the mounting point up and out an inch or so. Will the Jeep swag relocation bracket work for this?
Old Feb 7, 2014 | 10:22 PM
AlexjeepVb's Avatar
Im pretty sure the steering stabilizer comes with relocation hardware included.
Old Feb 8, 2014 | 12:25 AM
egeli's Avatar
It comes with a new track bar bolt that has a stud on the end of it where the stabilizer mounts to. If you have a raised track bar mount it has to mount to the stock track bar bolt location. The other end clamps to the tie rod and will be far enough from the drag link. The clamp to the tie rod only for stock size tie rod diameter, if you tie rod has a larger diameter than stock you can get a bigger clamp from fox.
Old Feb 8, 2014 | 02:04 AM
Monte417's Avatar
Google synergy steering stabilizer relocation bracket
Old Feb 8, 2014 | 07:31 AM
The kit comes with everything you need. As said previously you don't need to buy a bracket.
Old Feb 8, 2014 | 07:45 AM
Monte417's Avatar
thats true the only problem is if you use the trackbar bolt the kit provides you will be losing the 9/16 trackbar bolt if you have one installed. I had the 9/16 bolt installed on my axle side trackbar mount and did not want to replace it with the smaller bolt that came in the kit so I got the synergy relocation bracket
Old Feb 8, 2014 | 05:43 PM
A friend of mine just bought this and he did not like the mounting point so he is gabbing a relocation bracket. Saying it doesn't need a bracket is like saying your jeep doesn't need a lift kit. You're right, it doesn't need a lift kit, we want lift kits on our jeep.
New question though, I'm getting the RK drag link/flip kit. Is anyone else running the RK drag link flip kit and the Fox ATS stabilizer and do you have a pic?
thanks
Old Feb 8, 2014 | 07:05 PM
thanks
Good for your friend. Maybe he's just too picky. But the answer is still you don't need a relocation bracket with this SS.
I have no idea what point you are trying to make about lift kits but it makes absolutely no sense. Most people add lifts to fit larger tires etc. not just for shits and giggles...
