Front adjustable Track Bar installation??
Old Sep 13, 2012 | 06:35 AM
MtraXX's Avatar
Default Front adjustable Track Bar installation??
So yesterday I had my shop install my front and rear adjustable track bars and I have a mounting question in regards to the front.
I previously had a BDS relocation bracket on the front and rear and they didn't remove the front relocation bracket to install the adjustable. Instead, they mounted the adjustable to the relocation bracket and said this would allow more clearance for the steering stabilizer since its now mounted on the top rather than bottom.
Make sense?
What is best? To mount the adjustable track bar to the stock mounts or keep the relocation bracket for clearance?
Old Sep 13, 2012 | 07:57 AM
MtraXX's Avatar
Anybody have pics of their adjustable track bar mounted with a steering stabilizer? I want to compare to what i have....
Thanks!
Old Sep 13, 2012 | 08:22 AM
Croce's Avatar
I dont believe an adj trackbar should be using a trackbar bracket since well... its adjustable lol
and it may cause your steering geometry to be off
I had the RC 3.5" Kit. I removed both the trackbar relocation bracket and drop pitman arm and used just the Adj trackbar
Old Sep 13, 2012 | 09:31 AM
MtraXX's Avatar
Riiiight, which is exactly what i said to my shop as they were installing the bar but they said it would be better to keep the bracket so the stabilizer doesnt get wacked out of shape.
Anybody have pics of their adj bar with a stabilizer?
pics attached of what i have on now. Have been driving it all day and haven't had any road manner issues...
Name:	Adj track bar 003.jpg
Old Sep 13, 2012 | 10:01 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Adjustable trackbars recenter your axles, trackbar brackets (raised/drop) help to correct the geometry. Now both are not needed in all lifts.
Old Sep 13, 2012 | 10:21 AM
MtraXX's Avatar
With that said, should i leave the bracket?
Old Sep 13, 2012 | 10:43 AM
Freewill's Avatar
If the bracket is there to change the angle of the track bar and reduce bump steer, then it works as well with either track bar.
If the bracket is only there to center the axle when using a stock track bar then it might as well be removed.
Its probably not hurting anything either way.
Old Sep 13, 2012 | 11:02 AM
TeraFlex's Avatar
That would depend on how it handles for you now. Do you have bumpsteer?
Old Sep 13, 2012 | 11:20 AM
MtraXX's Avatar
Ahha, the shop said it would be best to avoid with bump steer.
No bump steer here, , guess my question is answered...
It stays as is.
Thanks guys, much appreciated feed back.
Old Sep 13, 2012 | 12:26 PM
AussieTom's Avatar
If you leave the bracket, don't you have to add the drag link frip as well, or drop pitman arm.
