Front adjustable upper or lower control arms?
I've searched and read alot of threads regarding using adj. upper and lower control arms and still can't really seem to find a definitive answer on which to go with.
In my particular case(front 1310 cv driveshaft vibration in another recent post I made) I'm looking at possibly having to raise my pinion up a few degrees. Should I use uppers and lengthen them or use lowers and shorten them? Or bite the bullet and get both?
Thanks
Thanks
If you go uppers, you would be shortening them, if lowers you lengthen them (if lifted). Lowers cost more but that is the preferred ones to get first and are beefier than stock arms. The uppers are a PITA to install, I recall you have to cut one of the bolts off because of clearance issues. I would go lowers.
What is telling you to lengthen uppers? I would imagine doing so would make your steering flighty with too much castor? Did you get an alignment and are they telling you to adjust your pinion this way?
https://www.jk-forum.com/forums/show...engthen+uppers
From what I understand: Either lengthening the uppers or shortening lowers is going to lower the caster which will raise the pinion up a bit. Shortening the uppers or lengthening the lowers is going to increase the caster which will drop the pinion down a bit.
Or am I missing something here?
Have seen this in at least one post here:
When you lift your jeep it will make you have less than proper (4.2) caster angle and this will cause you to pucker some unless you have driven older cars that drove this way new. The idea is to correct this back and it is done by making top arms longer or bottom shorter as stated. I am running mine at 5.1 with 3.5" lift and it tracks very well and has no wandering issues at all. I think front lowers and rear uppers are the preferd ones to buy first if you are going to buy them 2 at a time. Rear uppers will allow you to adjust out "binding" of rear coils. Front lowers generally have more adjustability than uppers from what I have been told. There is some more information on this in the newbie FAQ and in writeups.
We sell both sets in the SRS bushings/heims
