Front axle ball joint removel tools.
Old Mar 16, 2010 | 02:09 PM
longshank's Avatar
Default Front axle ball joint removel tools.
Hello,
Looking to get the dynotrac ball joints, need to know what special tools are needed to remove and fit these joints.
Old Mar 16, 2010 | 02:31 PM
zoeydad's Avatar
I just installed the DynaTrac ProSteer ball joints in mine this weekend.
The adapters for the press you need can be found in the Harbor Freight Master adapter set here: www*harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=46389
You'll also need a C-Clamp press, of course.
I have the HF 4WD set; it does not have the right adapters. Also tried the loaner tool program at Advanced Auto...no luck. Had to get the "Master Set".
The DynaTrac installation sheet lists some Miller #'s
Miller Kit 6289
C-Clamp (Miller C4212F)
Press Tools (MIller 6289-1, 6289-3, 6289-4, 6289-5, 6289-12, 8975-2)
Hope that helps.
Old Mar 16, 2010 | 03:31 PM
CTNEDGE's Avatar
Miller Kit 6289
Hope that helps.
Do you have to use a press or can you get away with a vise?
Old Mar 16, 2010 | 04:07 PM
zoeydad's Avatar
I would want the C-Clamp press. The adaptors have a ring ridge that keep them from sliding out of place on you. It took a lot of force to get my old lowers out (which had only been in 6 months) and I think it would have been pretty scary with a vise. fwiw
Old Mar 17, 2010 | 10:15 AM
longshank's Avatar
Many thanks for the info, will look for the miller bits.
Nice one.
