front coil problem
Old Mar 3, 2008 | 02:02 PM
2K1TJ's Avatar
Originally Posted by 2k2wranglerx
sounds to me like the control arms are slightly out of adjustment. your axle spring perch isn't perfectly underneath your upper.
is this a big deal? no not really. it did it on my TJ when i put the 8" springs. I had the RE long arms adjusted out all the way.
Did you check for this yet? That's my guess too.
Old Mar 3, 2008 | 07:47 PM
bswaltm's Avatar
Default damn
5.5" rk lift here same lift diffrent problem, mine not so bad but in the rear driver side about an inch higher than the pass. hearing some people are having problems makes me think i should get mine fixed, i thought it was somthing i did while jumping my jeep
Old Mar 5, 2008 | 08:24 AM
jonsjeep's Avatar
excellent ideas. thanks for the input guys......
