Front coil spacer install with spring compressor
Originally Posted by bigf350sd
X2. I did mine like this, also. Once the shocks and sway bar links are disconnected, and i also removed the track bar bolt, I had jack stands under the frame, just behind the lower control arm mounts, and eased the axle down. do the entire axle at once, rather than one side, doing one side at a time will bind the control arm bushings, and not allow it to droop as far. Doing it this way, pretty much the only thing limiting droop is the brake lines.
Anyone ever try installing a spacer using spring compressor? I just finished my OME lift and ended up with a rake. I'd like to get it level but hate to redo the whole install again, damn it, LOL!
I'm thinking do one side at a time, remove wheel, disconnect shock and sway bar link and use compressor to pull the spring, add 1" spacer and reinstall then do other side. Thoughts?
Be safe and avoid coil spring compressors.
Jack that side to take the load off springs, remove compressors.
...... and why is this?
