Front end sagged, new springs needed?
Old 02-29-2012, 03:22 AM
vulcan classic's Avatar
Default Front end sagged, new springs needed?
Ok I installed an AEV 2" spacer lift with shock extensions and switched to 33's and 15x8 wheels when I bought my 2012 2dr Rubicon. I have since added front bumper and winch, so the front end has dropped nearly an inch. I was thinking of swapping the stock front coils with some OME heavy duty springs or even a set of 4dr Rubicon springs to get it back to near level.
I would like to eventually complete the OME set front and back to run 35's. Can I do the springs in front for now and add shocks and do the rear later? Thoughts?
Old 02-29-2012, 04:18 AM
Saharaunlmtd's Avatar
My front end sagged a good bit when I added an AEV front bumper to my TF BB so I swapped the front spacers for 3" coils and left the rear alone until I add a rear bumper.
Old 02-29-2012, 04:22 AM
Will the stock shocks w/extensions work ok with OME 616 HD springs?
Old 02-29-2012, 04:48 AM
They will "work" but it's going to limit your droop.
From Northridge, you could get the coils shipped for $166 and the front nitro charger shocks for $170 for a total of only $336.
BUT, I believe that will get you to the height where you need exhaust modification on the 2012. You will need to research that piece.
Old 02-29-2012, 05:54 AM
Ryan0260's Avatar
If it was me I would just deal with the sag until you save the money to do the complete lift
Old 02-29-2012, 06:56 AM
JK-UTE's Avatar
x2, I can deal with an inch of sag until I could get the complete set up... just my $.02
Old 02-29-2012, 07:03 AM
Lyman21's Avatar
I jus got a bumper and winch. Adding proly 160lbs. I jus bought 50 dollar leveling kit to help out the sag
Old 02-29-2012, 08:07 AM
Yes, but I already have 2" spacers up front, along with the factory isolator, and my understanding is it's not a good idea to use more than one spacer on each spring. I don't think anyone makes a 3" spacer.
So maybe I'll go with just the HD front coils and shocks from OME, since I have a soft top and stock bumper and tire carrier in the back.
Old 02-29-2012, 09:30 AM
Rub61's Avatar
You should be able to find OEM HD springs for sale on the forum or maybe ebay. Lots of people have left overs when they do there lift kits. Just figure out the P/N's you need and go searching.
Should save you a couple of hundred bucks.
Old 02-29-2012, 09:53 AM
TMP-JK's Avatar
I have a set of the OME HD coils ill sell you. PM me.
Quick Reply: Front end sagged, new springs needed?
