front shaft gone?? or another issue??
Old Feb 25, 2008 | 06:20 PM
mccostlin's Avatar
Default front shaft gone?? or another issue??
on the way home tonight I noticed a little roar when I was running about 60mph let off the gas and it seemed to quiet down, then went away at 35 when I got into town. I got under it when I got home and checked my front shaft ( which is going in for warranty replacement on friday) and there was a little play at the Tcase CV which is the one leaking grease. you think the drive shaft is the culprit or should I be checking something else out? I couldnt find anything out of place or any rubbing issues. I just dont want to drive it too much if it might be something else.
Old Feb 25, 2008 | 06:31 PM
muddpuppy01's Avatar
wheelbearings
Old Feb 25, 2008 | 06:41 PM
mccostlin's Avatar
Default wheel bearings
Originally Posted by muddpuppy01
wheelbearings
You think they could go after 10k Miles?? i will check it out.
thanks,
Old Feb 26, 2008 | 01:33 PM
they could of been damaged by someone installing your tires or just a defective from the factory
drive shafts dont roar they click under load
