Front shock hoops
Old Sep 14, 2014 | 12:21 PM
Dahmer's Avatar
Default Front shock hoops
I see on pretty much every type of offroad vehicle, Toyota, other model Jeeps, trucks, etc. that they offer and a lot of people use shock hoops. I can see being able to adjust your shock positioning for custom up and down travel as being beneficial and being able to run longer shocks without using coil overs. Yes I know the benefits of coil overs but I'm not getting coil over. I know on my jeep that I can't find a shock that offers just the right amount of up and down travel without altering the shock position some. So why do people not use this technique on JKs or do they and I'm not finding it?
Old Sep 14, 2014 | 01:12 PM
TheDirtman's Avatar
There is no room for the cross brace the hoops in the JK engine compartment without major work relocating the stuff in there. Most of the tower designs out there are stronger and have more weld surface over a hoop set up that has a lot of leverage placed upon it.
Old Sep 14, 2014 | 06:34 PM
Dahmer's Avatar
Ok cool. I figured there had to be some reason considering the number of kits you see for the older jeeps.
Old Sep 14, 2014 | 07:16 PM
jaker t5's Avatar
Most of the jk guys who want to run customs shocks will change out the stock shock tower for a ford shock tower that way they can run longer shocks
I did something similar to that but made my own mounts , I now run 12" long body shocks
Old Sep 14, 2014 | 09:08 PM
D_engel's Avatar
Yupp, Ford shock towers are cheap, plentiful and just plain work.
Old Sep 15, 2014 | 07:35 AM
Maertz's Avatar
Yup there dirt cheap. I was able to fit a 12" travel shock on stock mounts though. But see alot of ford towers. I chose hoops but will be adding a cross bar over the motor.
Old Sep 15, 2014 | 09:50 AM
big dr's Avatar
I can say first hand,, towers in the JK are a Pain in the ars! Had to put the computer on its side,, ditched the windshield washer fluid reservoir, no more air box(had to go K&N),, and the crossbar is seriously tight. But,, it is soo sweeet!
ID:	575737   Click image for larger version
ID:	575738   Click image for larger version
Old Sep 15, 2014 | 11:04 AM
TOTL Innovations's Avatar
Former Vendor
Very nice
Old Sep 15, 2014 | 11:51 AM
jaker t5's Avatar
What's your collapsed and extended lengths
This was before using stock mounts
After
Old Sep 15, 2014 | 05:11 PM
Dahmer's Avatar
Wow Big Dr that's a pretty insane shock setup!
What Ford are y'all getting these off of, any install pics? May be more modding than I'm interested in. 12" shocks sounds nice especially since I'll never be able to get coil overs.
