Front spacer for 3" FT Lift?
I am having my new 3" Full Traction Ultimate Lift installed in a couple of weeks. I believe there is the need for a 3/4" spacer required to level out the front end to remove the rake. The guys installing the lift are not aware of any spacer available for the JK. Is the spacer required to remove the rake and where are you guys getting the spacer? Does anyone have any pictures with and without the spacer?
JK-Forum Founder
Sure, TeraFlex and many other companies have 3/4" spacers that you can buy. However, if you are planning to install a heavy steel front bumper and winch, I would recommend that you get your front coils replaced with a set of HD coils. It shouldn't cost you anything extra and it will definitely level out your ride even with a heavy bumpre and winch.
