Front upper control arm bushing replacement
Old Jul 14, 2015 | 06:48 PM
Cat Dr.'s Avatar
Default Front upper control arm bushing replacement
Is there a write up on replacing the bushings on the front axle for the upper control arms. I have an 08 2dr rubicon. It looks like the drivers side will hit the plug for the electric locker and the passenger bracket does not look strong enough to use a hammer to drive it out. Any suggestions would be appreciated. Thanks in advance.
Old Jul 14, 2015 | 06:52 PM
kjeeper10's Avatar
Vet Army
Its not easy thats all i can say.
Old Jul 15, 2015 | 04:03 AM
T&ERun's Avatar
I've never replaced them but I'm sure an air chisel (with a flat bit) is what you'll want to use to drive them out. I also think you just use a regular or ball-peen hammer to drive in the new ones. Again, I've never done them but this is what I would do.
Or:
If they are like a mid 90s Mustang 8.8 axle there is a fairly easy way. When I replaced mine on my Mustang years ago I used a drill (with about a 7/16" bit) to drill into the rubber bushing. Once through the drill will actually "walk" it's way all the way around the rubber bushing. Once you are all the way around the center steel sleeve will fall out. After that you can use the air chisel/hammer to crush the outer steel sleeve to get it out. Not sure if the Jeep's are the same style as the older mustangs though sorry. I would check but my stock axle for the Jeep is long gone.
Old Jul 15, 2015 | 04:11 AM
kjeeper10's Avatar
Vet Army
To replace a stock clevite bushing i drilled 8-10 1/2 holes around the dia. Next punched the middle sleeve out. Thats the hardest part. Getting the shell out is easy.
Old Jul 16, 2015 | 12:27 PM
Cat Dr.'s Avatar
Default Front axle bushings.
Thanks for the response. I have an air chissel so that will be no problem. The fitting for my electric locker is in the way. I take it I just unbolt and pry out of the housing. I guess it is probably on an O ring. Is there enough wire in the housing to lay it to the side while I drive the old out and the new in?
Old Jul 19, 2015 | 02:40 PM
kjeeper10's Avatar
Vet Army
Tie a string to the wires. Be careful prying up the clip. If you can use a small pair of channel locks, slowly and carefully wiggle the clip out of the housing.
