Frustrated with trying to get front track bar back in place... please help
Old Jul 28, 2012 | 02:21 PM
cbrown67's Avatar
Default Frustrated with trying to get front track bar back in place... please help
I am installing a Teraflex 3" lift with front lower controls and I can not get the bolt hole on the axle lined up with bolt hole on the front track bar. How do I get this back in place? Does it go back in the same spot or does a different hole need to be drilled for it?
Thanks in advanced.
Old Jul 28, 2012 | 02:25 PM
gearheadette's Avatar
What do the directions say?
Old Jul 28, 2012 | 02:29 PM
Freewill's Avatar
Just put a JKS adjustable front trackbar in mine last night; last step of installing a 2.5" lift.
With the frame end of the trackbar attached and the tires on the ground, my friend just rotated the steering wheel a bit to make the axle end holes line up. Once it lines up, the bolt goes in with just fingers.
Old Jul 28, 2012 | 02:36 PM
JKOwens's Avatar
x2 on this one. Have a friend turn the steering wheel.
Old Jul 28, 2012 | 04:04 PM
dave7200's Avatar
What worked for me was have jack stands under the frame so little or no weight is on the axle then I used a ratchet strap going from the passenger side axle to the driver side frame. Just ratchet the strap until the whole lines up.
Dave
Old Jul 28, 2012 | 04:14 PM
cbrown67's Avatar
Thank you guys very much the directions I have had nothing about reinstalling the bar I'm going to try what you guys suggested in the morning.
Blakspire's Avatar
Steering wheel trick is the magic trick.
Old Jul 28, 2012 | 04:17 PM
scooby snacks's Avatar
I used a strap and lining everything up was very easy.
Old Jul 28, 2012 | 07:02 PM
Jhen's Avatar
X2
Old Jul 29, 2012 | 10:40 AM
cbrown67's Avatar
Steering wheel trick worked perfect!
