FT 3" Ultimate and Squeeks
Old May 10, 2008 | 08:30 AM
  #21
JK07's Avatar
Derekls you are right i just went out and checked there is absolutely no room to wrap a rubber sheet
I have to think about something else now
Originally Posted by derekls
The rubber peice might work, but it seems it would have to be a super tiny rubber sheet lol, cause there was pretty much no room while putting in my track bars
it was a pretty tight fit.
The squeaking doesnt bother me to bad, it only is there when I roll at slow speeds
I know I greased the heck out of it when I installed, so if I just leave as is would it hurt anything? As in is the noise an indication of something that is going to happen if I dont clean and regrease, etc
Although next tues (my day off) I plan to reloc the evap can, install a snorkel, put zerk fittings into the track bars, and fix my steering stabilizer ( I know, a busy damn day lol)
Old May 10, 2008 | 08:32 AM
  #22
mcnaught6's Avatar
a few mud baths don't destroy bushings. it got to be a bad joint.
lots of people have had noise from FT parts. apparently, only the moderators of this forum know how to PROPERLY grease a joint with a zerk fitting.
and you'd better get on the phone with FT, because they don't reply to e-mails.
Old May 10, 2008 | 08:45 AM
  #23
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
my Ft ultimate is quiet ,no squeaks ,clunks or anything like that. When we did the install we did greased the heck out of all the bushings with a white lithium grease and i have greased them since just to make sure everything is lubed well.It is diffucult to get to a couple of the zerks for sure.Just make sure they are positioned so you can get to them and things are easier.
Hope your problem goes away soon,i really do feel it is a quality kit .The components are all beefy and well made in my opinion.
good luck
Old May 10, 2008 | 09:54 AM
  #24
jake's Avatar
Does anyone have access to the FT Ultimate install instructions. PDFs or can scan them for me? I let a shop put mine on, big mistake. I need to double check a few things if anyone has them. Thanks in advance for the help.
Old May 10, 2008 | 10:02 AM
  #25
bly109's Avatar
I dont have the actual FT instructions... BUt here is WOL's Write-up if it helps you
Old May 10, 2008 | 10:16 AM
  #26
jake's Avatar
Thanks Bly, but I was hoping someone might have the actual instruction from FT. I did use WOLs write up to redo the screw ups on my front end.
Old May 10, 2008 | 11:50 AM
  #27
Rubimon's Avatar
WOL takes the manufacturers instructions and eleaberates on them making them easy to follow with plenty of pictures. You wont be missing anything by using his write-ups.
Old May 10, 2008 | 12:15 PM
  #28
Coldfire's Avatar
My truck's lift had a sqeak that I could not get rid of for months even though it had a zerk fitting. I pumped tons of grease into that thing about four times before realizing it must be the grease just isn't getting where it needs to be (Obvioulsy ). I always greased it in on my sloped driveway. I had a Eureka moment and reversed the truck into the driveway, greased again, and no more squeak.
Anyway, the moral of my story is that perhaps if the squeak is more noticeable at certain times,you can try to determine how to best lube. For example, when flexed or parked on a slope etc..
I know its not much, but it might be worth considering. I know how irritating it can be.
Old May 10, 2008 | 07:14 PM
  #29
derekls's Avatar
I think the track bars are really well made but it should have came with a zerk fitting on both front and rear from the factory, should have came like that in my opinion... make life so much easier
Mine only squeaks when I am rolling at a slow speed or taking off.... sometimes when turning right slowly
Old Jul 2, 2008 | 08:19 AM
  #30
mikeyfl's Avatar
after a good powerwashing, i have gained a front end squeek. i usually have the radio cranked, but the past couple days ive been pulling into work with the radio off and i hear it.
going to do a once over tonight when i get home from work, weather permiting.
