Fuel Pump Wiring Breakdown
Old Apr 14, 2014 | 12:44 PM
Maertz's Avatar
Default Fuel Pump Wiring Breakdown
I am wondering if anyone can let me know what each wire does on the fuel pump. If i recall correctly there are 4 of them. I found a wire diagram but suck with electronics.
http://www.trailduty.com/temp/fuelpump.pdf
It seems like itd be the 4 wires in the upper right corner, but for some reason i swear one was pure black. I will have to double check when I get home. If that diagram is correct i would use c1 as my ground, but would i use c5 or c1 on the new fuel pumps power wire. My new fuel pump has a ground and positive only.
Old Apr 14, 2014 | 01:27 PM
ronjenx's Avatar
At the fuel pump module connector:
Pin 1: Black, ground.
Pin 2: Dark Blue, Fuel Level Signal.
Pin 3: Dark Blue/Yellow, Fuel Level Sensor Ground. (Electronically grounds on one of the TIPM circuit boards)
Pin 4: Dark Blue/Orange, Fused Fuel Pump Motor Power
Here is something you may find interesting if you have not seen it already: https://www.jk-forum.com/forums/stoc...-study-262093/
Old Apr 14, 2014 | 01:31 PM
Maertz's Avatar
Originally Posted by ronjenx
At the fue; pump module connector:
Sweet thanks, looks like ill try and hook up my pump to the black and the dark blue/orange. I appreciate your help.
Old Dec 28, 2022 | 07:07 AM
MIJeepSL's Avatar
To what connector doe it hooks up the fuel pump cable?
on the fuse box?
