Full-Time 4wd?
Old Feb 11, 2010 | 06:33 AM
earfixr's Avatar
Question Full-Time 4wd?
How hard would it be to covert an '09 Rubi to full time 4wd?
Just a new front diff and/or new t-case too? I'd love to keep it in 4 all the time and just lock the front diff when needed in 4Lo.
I'm guessing the front diff would need to be really open to pull it off safely? Would love to keep the stock T-case if at all possible for crawl ratio and cost reasons.
Old Feb 11, 2010 | 06:45 AM
john smack's Avatar
just leave it in 4hi
I dont know why you would want to do this
Old Feb 11, 2010 | 06:47 AM
beamme84's Avatar
you mean to convert it to AWD?
reddragons's Avatar
Interesting concept for a JK,
I had a cj7 that was full time 4 wheel drive. The gas mileage was terrible though. Why do you want full time 4 wheel drive?
Good luck with the conversion.
Old Feb 11, 2010 | 06:54 AM
Joisey's Avatar
this is an easy mod,
Lean forward
strech out right arm
grab knob
pull down
lean back and drink a cold one cause ur done.
Old Feb 11, 2010 | 06:56 AM
spinlock's Avatar
There may be other changes required such as PCM programming, but the principal would be the transfer case.
For full time 4WD (the old school term) , the TC needs to provide differential functionality (slip) for a much larger set of conditions, such as when all wheels have full traction (road) but the vehicle is turning and braking.
Old Feb 11, 2010 | 06:59 AM
RDY4RKS's Avatar
Easy conversion. Just move the lever that is next to the gear shift to 4HI. The gear ratio for 4HI is the same as 2wd.
Old Feb 11, 2010 | 07:12 AM
spartan99's Avatar
Easy conversion until you destroy your JK.
dadgummit's Avatar
All joking aside you would need a way for to disconnect the front from being locked to the rear. This is usually done with some type of center differential which would mean completely redesigning the drivetrain.
Old Feb 11, 2010 | 07:18 AM
BlackNorthernJK's Avatar
bingo
need a center differential to pull this off, then you can have AWD
