Full Traction 3" + 35's - JK Rubi Issues!
Old Apr 3, 2007 | 12:05 AM
degenerate's Avatar
Originally Posted by mmccurdy
I installed an ultimate kit and 35's over the weekend, and I too have the "wander" and ESP issues despite trying once (read: shooting in the dark) to adjust the camber by pulling the front lowers out about 5/8" longer than stock. I basically have no idea what I'm doing in this department, so I've got an appointment on Thursday with a reputable 4x4 shop to have them check everything out before I hop in it on Monday to drive from SF to Tucson
All in all, it's driveable, but I would really like to dial things in to get the "better than stock" ride that everyone claims with the ultimate kit. I'll see what happens on Thursday and make sure I debrief to understand what they actually adjusted (since I left the uppers stock length going in).
you went the wrong way with your adj. arms. the 4x shop should be able to dial it in right for you.
Old Apr 3, 2007 | 04:28 AM
Piginajeep's Avatar
Just a guess. But thats probley your problem.. I had some wondering issues with my ulitmate kit, thats was ultimately the problem. I had to adjust my control arms. If you dont have them the exact same lenth it'll also pull you left or right.
Old Apr 3, 2007 | 07:48 AM
mmccurdy's Avatar
Doh! I was wondering about that. My very scientific method involved making little parallelogram motions with my fingers trying to figure out the effect of dropping the axle 3" -- not surprising then that I got it wrong
Old Apr 3, 2007 | 08:02 AM
Rubimon's Avatar
I am pretty sure you are way shallow on the caster if you left your uppers the stock length. I am guessing they need to be shorter than stock. I have my uppers as short as they go because I don't have the lowers yet. Basically, if your springs and shocks are off your bump stops should hit right in the middle. I guess another way to tell if you have enough caster is you steering wheel should snap back to center after make a slow turn.
Old Apr 3, 2007 | 11:53 AM
GOCACHN's Avatar
Originally Posted by Jolly Roger
How long was your FT premium lift on order??
I ordered from 4wd.com on Feb. 13 and it came last Wednesday.
Old Apr 3, 2007 | 12:34 PM
BYU JK's Avatar
Mine will be here on thursday, but I have little to no knowledge on how to install it, so I am paying a professional to do it for me. I figure my life is at stake and I would rather put it in the hands of someone who knows what they doing. I'll let you know how it goes
Old Apr 5, 2007 | 09:28 PM
LinkSync's Avatar
I added an after aftermarket steering dampener after putting on the 35s
I dont know if your kit comes with one or not.
Mine didn't.
It should as it helps.
Old Apr 6, 2007 | 02:12 AM
Jolly Roger's Avatar
Good for you guys. I waited 5+ weeks. After many non truths about it from FT. I gave up and ordered a tereflex.
Old Apr 6, 2007 | 07:34 AM
Rubimon's Avatar
Could you post the length of your arms (from the center of each hole)? That would help give me some comparison when I get my adjustables.Thanks
Old Apr 6, 2007 | 11:32 AM
GOCACHN's Avatar
The Ft lower fronts are 23 inches,the rears are 21 inches.
