Full Traction front Track Bar question - (Jam Nut size)
Old May 3, 2009 | 05:13 PM
HG07JKRubi's Avatar
Default Full Traction front Track Bar question - (Jam Nut size)
I'm trying to loosen the Jam Nut on the Full Traction front track bar and don't have a wrench big enough to loosen the jam nut which is on there really tight. (According to the install instructions it was supposed to be only hand tightened during installation). Anyway - My axle is off about 1/2" and I want to recenter it by adjusting the track bar. I can get the axle mounted side of the track bar off but can't loosen the jam nut on the track bar to make the necessary adjustment and I don't have the right sized wrench to try to loosen it. Anyone happen to know the wrench size needed for this nut ? Looks to be 27-30MM or just slightly over 1" before I run to the hardware store and buy the wrong size ???
Old May 3, 2009 | 05:19 PM
kflash's Avatar
Don't worry about the correct size. Head to Harbor Freight and get a massive adjustable wrench!
Old May 3, 2009 | 05:43 PM
edwin907's Avatar
Exactly, I have a 360mm Craftsman, it works perfectly, keep it in the tool bag in the back.
Old May 3, 2009 | 05:45 PM
HG07JKRubi's Avatar
Good suggestion...thanks
Old May 3, 2009 | 05:57 PM
mkjeep's Avatar
Or you could get a cheap pipe wrench. Even a small one will work.
Old May 3, 2009 | 08:54 PM
Piginajeep's Avatar
thats what I use
Old May 4, 2009 | 04:04 AM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
damn I thought about getting a pipe wrench, but thought it would be ghetto I got a damn $44 craftsman adjustable wrench I should have gone with the pipe wrench haha
Old May 4, 2009 | 11:57 AM
mkjeep's Avatar
Not ghetto unless it was chromed, now if you drove around with the pipe wrench still attached, that'd be redneck.
Old May 4, 2009 | 01:41 PM
Northridge4x4's Avatar
Sponsoring Vendor
Are you saying it says not to tighten this up in the directions?
David
Old May 4, 2009 | 04:23 PM
HG07JKRubi's Avatar
David
No. I'm just simply trying to get it loose at this point.
