Full Traction Sway Bar Discos
Old Jun 2, 2012 | 08:52 PM
10frank9's Avatar
Default Full Traction Sway Bar Discos
Special request...
Anyone running a Full Traction lift with FT Sway Bar Disconnects? Can I get a picture of them installed?
Bought them and installed them but they don't look right. Bought them off of a forum member and there were no instructions. Any help would be appreciated. Thanks in advance.
Old Jun 4, 2012 | 08:55 AM
10frank9's Avatar
Bump for some help.
Old Jun 4, 2012 | 09:12 AM
bigbluejk's Avatar
I had some but never installed them and used teraflex ones instead. But, don't they have a pin with a hoop around it that goes on the bottom part and a pin going thru the top part where it connects to the swaybar?
After looking at their website it seems they have maybe 2 styles for the JK. What do yours look like? You have a photo?
Old Jun 4, 2012 | 04:37 PM
10frank9's Avatar
Thanks, it only had one end which disconnects. It appears that it discos at the top end which is wired. Was hoping for photos so I could install them correctly.
Old Jun 4, 2012 | 05:25 PM
jsears's Avatar
The part that discos usually goes on the bottom. When you disco them you zip tie them to the sway bar.
Old Jun 4, 2012 | 09:37 PM
10frank9's Avatar
Thanks, that's the problem. Seems like the top is made to disconnect. Top has that flexible joint which sort of matches the oem so I figured it goes on top. Bottom does not disconnect.
Anyone with pictures please help.
Old Jun 5, 2012 | 11:26 PM
10frank9's Avatar
I jimmy rigged the sh@& out of it and it works so.... Thanks anyways
