future setup!
Old Nov 26, 2011 | 12:02 PM
nateb's Avatar
i just checked that bumper out, good choice! i was not expecting 1200 bucks, but i do like it. Now i guess ill find a front one to go with that lol... if im gonna do it, guess ill do it all
Old Nov 26, 2011 | 12:27 PM
nateb's Avatar
whats some opinions on the tires and wheels i posted? will i be able to run that setup with a 3.5 in lift?
Old Nov 26, 2011 | 12:55 PM
Kozmothedog's Avatar
Talking
35's will be fine with 3.5 inch lift I have a 4inch lift but there's boat loads of room
I run 35's 9 inch rim with a 4 inch teraflex springs Rock Krawler mid arm setup with bilstein 5160 reservoir shocks
I had to change my drive shafts out after around 10,000KMs and went with JE REEL
Old Nov 26, 2011 | 01:14 PM
knnphillips's Avatar
I'm running 35/12.5/15 on 2.5 Teraflex lift with fenders trimmed and have plenty of room not even running their extended bumpstops.
Old Nov 26, 2011 | 01:52 PM
nateb's Avatar
that looks good! did you trim them yourself? ya there looks like there is plenty of room, thanks! are the bolt patterns all the same on the jk?
Old Nov 28, 2011 | 11:26 AM
nateb's Avatar
does anyone think i will have a problem with the width of the tire and rim fitting on the jeep? also, if i get 1" coil spacers, and add them to the 3.5" lift, will that act as a 4.5" lift and add more stress to the drive shafts? or does it not work like that, and the drive shafts should be fine?
Old Nov 28, 2011 | 11:34 AM
scotty6336's Avatar
i dont think i should have a problem with the size rims and tire size, will i?
A wheel 10" wide, not to mention a 14.5" wide tires is gonna put a lot of stress on your axles, seems to me would make quick work of unit bearings/ball joints, etc. Would look damn good though.
Old Nov 28, 2011 | 11:37 AM
nateb's Avatar
do you think i would have a few thousand miles on road with that setup before my axles went? i will be moving to florida in june as long as its good enough to get me there i can fix it then.
Old Nov 28, 2011 | 11:42 AM
Bucko's Avatar
looks good, that should get you through 99% of the stuff in FL (gator clearance )
Old Nov 28, 2011 | 11:52 AM
nateb's Avatar
Thanks! just a few more months and it will be ordered. Just want to make sure i dont miss anything, or order something thats not going to fit...
