Gascap light????
Old Sep 30, 2013 | 12:47 PM
taylorfain2009's Avatar
Default Gascap light????
Ok so I hook my jeep up to a code reader comes back with Gascap and it's lit up Gascap on the dash. So I mess with the Gascap and stuff and it will not go off. Any suggestions?
Old Sep 30, 2013 | 12:52 PM
Gas cap usually means a few large leak, do you could have a leak somewhere else.
Sent via smoke signals
Old Sep 30, 2013 | 12:53 PM
FoxRacingJMC's Avatar
Most likely has to do with your EVAP canister and the ESIM (evaporative system integrity module) attached to it. If the ESIM is faulty/broken, or the EVAP canister is - it will throw the gascap light.
https://www.jk-forum.com/forums/jk-t...module-266321/
Old Sep 30, 2013 | 01:21 PM
wheezer's Avatar
Could it be something as simple as your gas cap needing replacement?
Did you take the cap off and look at the seal inside? Does it look like it's in good shape?
You didn't mention what year your JK is or how many miles you have on it. Mine's an 07 and at about 30,000 miles I got an evap system trouble code and all it took was replacing the gas cap with a new one.
My advise, start with the simple stuff before you dig any deeper in to it.
Old Sep 30, 2013 | 01:40 PM
Jersey_Devil's Avatar
Definitely try the cap first when going by the process of elimination cheapest is better first
Old Sep 30, 2013 | 02:00 PM
Could this be the problem? There is a cracked missing part on the front of the white plastic
ID:	501575   Click image for larger version
ID:	501576   Click image for larger version
Old Sep 30, 2013 | 02:26 PM
profebill's Avatar
Yes that is probably the issue. The location sucks. I covered mine with silicone after epoxying it back together and Zip tying it back under my Jeep
Old Sep 30, 2013 | 04:46 PM
That is a shitty design of jeep. Should have put it under a skid plate or something. Anyways ya that's the prob I'm going to epoxy it back
