Gear Noise with 4.88s
I just had a set of Superior 4.88 gears installed in my 2 door Rubicon. The fronts seem fine but the rears are quite noisy, both on acceleration and deceleration. The installer was concerned and had a second set sent along with a new master install kit. The result was the same.
Has anyone else noticed these gears to be quite loud?
Superior gears are usually pretty quiet even on install. But the rule of thumb is after about 100 miles of proper breakin they should quiet down. That is common with lower grade gears like Genuine Gear.
How would I check this? I have the 4.88's and don't have a whine, but a squeek (I have an auto) when I pull off the gas... a chirpy squeeky noise out of the front end somewhere... everything looks good though.
You would know if it was the bearings. It gets to the point where it sounds like a jet engine powering down. Some slight chirping when your slowing down may go for a bit until you've gone through a gear oil change (500 miles I think for new gears). The real thing to pay attention to is if the noise gets lowder.
Thanks for the suggestion - I appreciate the help!
Acceleration seems fairly close to what it was before the changes. I should be able to get it out on the trail this weekend and see how I like its performance there.
