GEARS options except Superior
Old Aug 28, 2008 | 03:24 PM
Hellbilly's Avatar
Thanks Davis! Well, that about clears it up!
Old Aug 28, 2008 | 04:11 PM
chuck45's Avatar
Actually I heard that the Superior gears for the JK were made in Europe.
At any rate I've got Superior 5.13's in mine and they are as quiet as the factory gears. I think it all depends on who installs them. I highly recommend using a shop that does lots of gears and will take the time to set them up right. I'd bet a poorly set up set of Dana/Spicer gears would be noisy. I'll do damn near anything to a vehicle, including rebuilding the engine, EXCEPT gears.
Old Aug 28, 2008 | 05:32 PM
JK07's Avatar
my major problem is to find a expert installer. Unfortunately in Oz so far according to my knowedlge no one has installed 4.88 or 5.13 in their JK. the last time there was a guy who tried to install 4.88 superior has so many problems that his rig was sitting with installer for a month and at the end he had to go back to original gearing. I have been also told that superior is very hard to install my question is why?
I just want to avoid any issues like bec the cost to do that is
The installer is asking 1200 for gears install
Superior Gear 4.88 package 700
Shipping 500
total 2400 bucks
The major issue comes with D30 not D44. I thought of swaping my front with D44 mopar rubi but again the Axle housing is for left hand drive and here is oz the steering mounts are on the opposite side which will require cutting and welding and i dont even have dimensions etc
any help would be great
Old Aug 28, 2008 | 09:14 PM
chuck45's Avatar
I don't know the situation in Oz but around hear there are two types of shops that do a lot of gears. The first is a 4x4/offroad shop that does a lot of lists and big tires where regearing is necessary. The shop I used does a lot of gears. I inquired and they said there is no difference in installing different brands.
The other type of outfit is the dedicated driveline shop. Every American town of decent size seems to have one. The do a lot of driveshafts and gears for commercial trucks. A lot of dealers and independant shops contract jb=obs out to them. Commercial users are fussy and expect gears to last several hundred thouand miles. When I regeared and added posi to my TJ I used a commercial driveline shop and 50k miles later everything is fine. When I did my 5.13's in my JK I used a local 4x4 shop that does a lot of gears and had good references. So far so good. You may have to drive to a larger population center to get your gears done.
Old Aug 28, 2008 | 10:05 PM
JK07's Avatar
Thanks for the reply. I actually just found out there is a shop who installed 4.88 gears in the Dana44 and front as first. He said he has not done d30 so far with 4.88
Is there any way to find out what is so hard to install 4.88 in the Dana 30 any advise or tip or trick from these professional installers in states
Old Oct 17, 2008 | 07:28 PM
AZJeeper's Avatar
Community Favorite
Originally Posted by Northridge4x4
Superior makes a ton of items in the USA but I am pretty sure the JK gears are made in china.
We had had zero issues with this last run of gears.
Alslo if you have yukon or alloy or any other brand of gears in your JK You have superior.
David
I did a little research trying to hunt down who makes what and where it's really made. Talked to Chad at Randy's Ring and Pinion, searched the web business directory, and cross-referenced part numbers. Here's what I found:
Randy's Ring and Pinion is also known as Ring and Pinion, Inc. The business is classified as Automotive Repair Shop and has 120 employees in three locations.
Randy's owns brands:
USA Standard Gear
Value Gear
Yukon Dura Lock
Yukon Gear & Axle
According to Chad, Randy's gets their Dana 44 gears from Superior Axle and Gear. These are branded as USA Standard Gear or if you want a prettier box Yukon Axle.
Superior Axle and Gear is also known as Foote Axle and Forge L.L.C., is classified as Motor Vehicle Parts and Accessories and has a total of 46 people. Their web site states "We are a 100% in-house manufacturer. We forge, CNC machine, heat treat, precision grind and spline right here in our Los Angeles facility."
Therefore USA Standard Gear = Yukon = Superior = Foote Axle and Forge = made in the USA -- At least for the Dana 44 gear set.
Couldn't find much on Alloy USA, LLC except that the business is classified as Auto and Home Supply Stores with a total of 6 people. Obviously they don't make their own gears.
Old Oct 17, 2008 | 08:40 PM
Piginajeep's Avatar
Zak i thought you were putting 60's in it?
Old Oct 18, 2008 | 02:16 AM
JK07's Avatar
Yep you are right I am going 5.13 with D60 as you have suggested
