getting the old muffler off--help!!!!
Old Mar 1, 2010 | 11:53 AM
stevedolce's Avatar
Default getting the old muffler off--help!!!!
i started on my rreplacment muffler--again. i used a ton of that PB lube stuff and a set of vise grips and i was able to get only ONE hanger off the rubber holder..took the grips, hooked one side to the base of the hanger, and then tried to push the nipple back thru the holder..
no dice..2 hours and was able to get one off..what am i doing wrong?
Thanks
Steve
Old Mar 1, 2010 | 11:57 AM
Locklain's Avatar
They are a beast to get off without an exhaust hanger tool. I ended up taking a sawzall to the old muffler hanger then it was a piece of cake.
Old Mar 1, 2010 | 11:58 AM
rinkishJK's Avatar
use a pry bar to get the rubbers off the posts. use lube as u said u did.
Old Mar 1, 2010 | 12:03 PM
JK-ADD77's Avatar
x2
Old Mar 1, 2010 | 12:04 PM
UGOTKERN's Avatar
Cut all that sh!t off..... if you move everything around too much you are going to loosen up the pipes that connect to the manifolds causing exhaust leaks...
Old Mar 1, 2010 | 12:06 PM
stevedolce's Avatar
the sawzall is my next step..i'm a bit of a dumbass. my first attemt on the sawzall was trying to cut thru the actual hanger! needless to say that didn't work. you guys are chopping the actual muffler pipes..right?
Old Mar 1, 2010 | 12:09 PM
rinkishJK's Avatar
if u sawzall it u cant put it back on ever.
like if u sold it or traded it in, or needed a backup.
i save all my parts.
Old Mar 1, 2010 | 12:10 PM
Locklain's Avatar
Nope, cut the metal hanger that is welded to the old exhaust. Then you will be able to slide the piece of metal backwards out of the rubber hanger. You will need some kind of metal blade for this though.
Old Mar 1, 2010 | 12:11 PM
JK-ADD77's Avatar
Whatever you want to cut or whatever you "need" to cut. Just make sure you are using a metal cutting blade. One time (at band camp), my DumbA$$ tried using a wood blade. I kept thinking..... "Why won't this cut?"
Old Mar 1, 2010 | 12:18 PM
stevedolce's Avatar
i'm not worried about selling or trading..once it's on, i'm not taking it off..i may need a thicker blade. it wasn't going thru the hanger.
i'm gonna as a newbie question here--should i worry about the sparks that kick off my saw/grind? it's near the gas tank & evap cansiter. my over active imagination is in overdrive.
