getting the old muffler off--help!!!!
Old Mar 1, 2010 | 12:28 PM
Locklain's Avatar
Originally Posted by stevedolce
i'm not worried about selling or trading..once it's on, i'm not taking it off..i may need a thicker blade. it wasn't going thru the hanger.
i'm gonna as a newbie question here--should i worry about the sparks that kick off my saw/grind? it's near the gas tank & evap cansiter. my over active imagination is in overdrive.
Hmm, I don't know if I would use a grinder right behind the fuel tank. That could cause some 'problems' if there are any vapors around. The only other thing I could think of is a pair of bolt cutters but they would have to be pretty decent size.
Old Mar 1, 2010 | 12:34 PM
UGOTKERN's Avatar
We cut everything..... pipes, hangers, clamps etc......
Even if you get the hangers off..... seperating the pipes is a PITA due to the corrosion and that fact the pipes have been baked together for a while....
Old Mar 1, 2010 | 12:35 PM
JK-ADD77's Avatar
Give it a try and let us know how it goes!
Seriously, If you use a Sawzall you should have to worry about anything.
Old Mar 1, 2010 | 01:21 PM
stevedolce's Avatar
i REALLY don't want to give in and spend the hundred bucks to have the guys at the muffler shop install it--
it's not the money-it's kinda the point of doing the work myself.
Old Mar 1, 2010 | 01:22 PM
rome07JK's Avatar
i used a dremel to grind down the little bump down then used WD-40 to get that little bastard off
Old Mar 1, 2010 | 01:23 PM
Locklain's Avatar
Don't do that, go down to your local autoparts store and pick up a set of exhaust hanger pliers if the sawzall isn't working.
Old Mar 1, 2010 | 02:07 PM
o7jk's Avatar
use chapstick! its a bitch just keep pushing!
Old Mar 1, 2010 | 04:56 PM
cojk's Avatar
Just did mine yesterday, the exhaust side was a PITA. Used a long screw driver from the bumper side out and pried like crazy, I did not have a good size pry bar to use. Finally got it. If I had a sawzall I would have went that way.
Old Mar 1, 2010 | 07:07 PM
JCKnauer22's Avatar
i used channel locks. no lube or anything, just the channel locks. i put the top half of the jaws on end of the steel hanger and the lower half on the back side of the rubber piece. a little work, some patience, and some carefully placed explicatives got the job done. i'm sure some PB or WD-40 would've helped immensely, but i didn't feel like going to the shed. the hardest part for me was trying to work off the actual joint in the exhaust where it goes into the muffler. have fun and good luck
Old Mar 1, 2010 | 07:28 PM
Zylfrax791's Avatar
what am i doing wrong?
You need to gain some strength in your hands cause its about as simple as spraying a little lithium lube on it and then pushing on the hanger rod with your thumbs and pulling the rubber isolator with your fingers....
