Going from 5.5 in to 4 inch lift need advice
Old 05-01-2014, 11:44 AM
kellyII's Avatar
Default Going from 5.5 in to 4 inch lift need advice
Ok, I'm currently running RK 5.5 inch lift, I'm gonna lower it to a 4" lift. I know I will prob have to get shorter sway bar links and shocks. I know I will have to re-set my caster on the front. But on the rear will I need to adjust my control arms? I know how and what rides best on the front but have no idea what to go by in the rear. Pinion angle or what??
Old 05-01-2014, 01:51 PM
TheDirtman's Avatar
You will want to adjust the pinion angle on the rear.
Old 05-01-2014, 01:53 PM
Maertz's Avatar
why do you need new shocks?
Old 05-01-2014, 02:12 PM
kellyII's Avatar
I know I will need to adj the rear pinion angle, just don't know to what angle. I know the front needs to be as close to 90 degrees as possible but unsure if the rear is the same.
Bc when I installed my rear coils to see how they fit my rear shocks were fully collapsed, I mean mashed ALL the way in
Old 05-01-2014, 02:14 PM
TheDirtman's Avatar
Point the pinion at the transfer case.
Old 05-01-2014, 02:17 PM
Maertz's Avatar
gotcha. I am assuming the shocks were bottoming out and acting as the bumpstop in the last setup then?
Old 05-01-2014, 02:40 PM
kellyII's Avatar
Exactly. I know I will have to make adjustments but didn't know if I needed to look for 90 degree pinion angle or what
Old 05-01-2014, 02:43 PM
Maertz's Avatar
yeah sounds like you will have a few things to fix from that old kit. But dirt covered the rear pinion for you. I always put an angle finder on the bottom of the diff (flat part) and then on the driveshaft and try to get them at the same angle.
Old 05-01-2014, 03:06 PM
kellyII's Avatar
I have no vibes or issues with the 5.5 RK, I will put my angle finder on it to see what it's at now and try to stay or get as close to the same angle ( pinion, drive shaft) after I install and get shorter shocks.
Quick Reply: Going from 5.5 in to 4 inch lift need advice
