Goodyear MTR/K vs. Nitto trail Grapplers
Old 04-23-2014, 12:42 PM
  #31
zedteamk2's Avatar
+1 on the Nitto Trail Grapplers.
They ride nice on the street, dont make a lot of noise and they dig in when it gets muddy.
Old 04-23-2014, 02:55 PM
  #32
12JKjeep's Avatar
Originally Posted by troyoffroad
Just so you know, Nittos are made here in the USA. I just bought a set of 37's and weighed them on a scale to get an actual weight. They all were exactly 83.5 lbs.
well 83.5lbs is a lot better then 95+ lbs that everybody says they weigh.
Old 04-23-2014, 03:24 PM
  #33
JayswranglerX's Avatar
If I stay with 35's I will keep getting the Kevlars.
If I go 37 I will look elsewhere.
The 37's on my diesel were horrible.
Always wobbled no matter what I tried
Sent from my LG-LS980 using JK-Forum
Old 04-23-2014, 07:03 PM
  #34
Tooadvanced's Avatar
Originally Posted by janders82
35 unmounted to 37 mounted and only gain 6 lbs? nope. these are all unmounted tire weights...i also found it surprising that there is only a 6lb gain from a 35 to 37. the Toyo is a 1350 so maybe that would explain a 14lb increase?
It confused me cause it said 37's on a 17 inch wheel. Thought you meant mounted..
Old 04-23-2014, 07:52 PM
  #35
sea bass's Avatar
Most reports that I've seen put them in the 85-87lb range. 95lb seems pretty high.
I keep bouncing back and forth between km2’s and tg's. I've had two sets of km2’s - might have to give the tg's a shot.
I don't know why but I do not like the way mtr's look. They have a very round profile where tg's have a very squared off look. I kinda like then flat read and sharper shoulder I guess.
Old 04-23-2014, 07:54 PM
  #36
n3tfury's Avatar
You're confusing the nittos with the toyos.
Old 04-24-2014, 03:16 AM
  #37
12JKjeep's Avatar
no every body I talk to say the nittos are are around 92lbs and the toyos are 95+ lbs. at least that's what I've heard.
Old 04-24-2014, 05:25 AM
  #38
Ill weigh a mounted nitto with 26k on em soon. Bet ya over 100lbs easy
Old 04-24-2014, 05:29 AM
  #39
n3tfury's Avatar
We're not talking about mounted weight.
Old 04-24-2014, 05:58 AM
  #40
WLFMOON's Avatar
I have both set of tires right now....the nittos are a heavy tire. The MT/R's are slightly lighter. No issues with balance on the MT/R's. I got them from discount tire and they mounted on rims.
Same with the nittos. The Nittos do have a slight vibration around 44mph though.
Quick Reply: Goodyear MTR/K vs. Nitto trail Grapplers
