Got TPMS air pressure reprogrammed.
Took the JK in to get a bad block heater replaced under warranty today. While in there I asked if they could reprogram the tire pressure on the TPMS. They weren't sure but said they would try and either way it would cost 46.50.
They were successful and I had it reprogramed to 28 psi; the pressure I run the 35" KM2's at. So now the indicator light on the dash is gone as is the chime. They said they weren't sure if it could be done because nobody had ever asked them to do it before.
So if that light and chime bug you they can fix it. I don't know how low they can go; but 28 was doable.
