Grill paint/ tips!?
Old Nov 24, 2011 | 03:00 PM
Zenabi's Avatar
Default Grill paint/ tips!?
What kind out paint do you guys use to paint your grills ? Any points an tips?
Old Nov 24, 2011 | 04:02 PM
Zenabi's Avatar
Of*.^^^^^^^^
Old Nov 24, 2011 | 06:19 PM
jesse0376's Avatar
i just sprayed it with primer first them a couple coats of flat black. havent had a chip yet.
Old Nov 24, 2011 | 08:42 PM
StrizzyChris's Avatar
I asked the same thing a month or so ago. I didnt know for sure if I would like it and did plastidip on mine. It has a nice dull textured black finish like bedlining, but any time I want i can peel it off and go back to stock. It takes two cans at 6/can. no prep or ruining your stock paint other than washing it with soap and water. heres a link to that thread
https://www.jk-forum.com/forums/show...Bedlined-grill
Old Nov 24, 2011 | 11:57 PM
jezzalachis's Avatar
Old Nov 25, 2011 | 09:38 AM
Originally Posted by jezzalachis
I'm going to add an aluminum grille and spray it black, have seen many do this and it looks great.
I have not seen this. Why replace it rather than just paint stock? and why with something expensive like aluminum? It can weigh that much less than that plastic stock grill thats like 5lbs?
Old Dec 1, 2011 | 02:47 PM
mangomonster's Avatar
just did mine this past weekend. i used 3m scratch pad to rough up the surface, washed it, then applied a adhesion promoter followed my 5 light coats of bedliner. i love it!
Old Dec 1, 2011 | 02:59 PM
Tonka_yellow's Avatar
Well you can go two ways I guess. One way is spray on bed liner and the other is just spray paint. If your going with the bed liner you can use some real rough sand paper. If your going to use just spray paint use fine sand paper. When I used the bed liner I noticed it stuck better to rougher surfaces. It's all about prep if you want it to come out good.
Old Dec 1, 2011 | 03:01 PM
I have been painting cars and using spray paint for a while. I worked in a body shop in high school so if you got any questions shoot me a pm
Old Dec 1, 2011 | 03:28 PM
DarkS1de's Avatar
Tonka, what bedliner paint did you use? I'm going to be painting mine this weekend and want to do it the right way.
Also do you think a heat gun will be beneficial?
I don't have 4 hours to do everything so I figured I'd shoot it with at least 3-4 coats of bedliner then use the heat gun to dry.
