Hanging JCR Bumper to Paint?
Old Jun 12, 2013 | 07:17 PM
mistasparkl's Avatar
Originally Posted by SpicedCrusher
Because there are oils and other containment's that get on the bare metal. Plus a sandblast gives a better adhesion, although this is mostly done prior to powder coating. The old wipe down with some mineral spirits and a rag would also do the trick. After a bumper is sandblasted it is bare and exposed to the elements. Any moisture in the air will cause your part to begin surface rusting. Although this may not be very noticeable to the naked eye, it will be present. The presence of this microscopic surface rust will compromise the adhesion of especially powder. Basically if your going to sandblast something prior to, it is best to apply what ever you are going to apply in a reasonable time frame thereafter.
Thanks spicedcrusher. Yep, for a perfect painting surface, and the best adhesion, and very uniform. Its also quicker than sanding by hand. Clean, wipe down, sandblast, wipe down, and shoot. Great if you have access to one. If not--no big deal, it'll take longer to prep is all, and you'd have to be a bit more meticulous w/ the cleaning and sanding.
Old Jun 13, 2013 | 07:24 AM
jstikel3's Avatar
Originally Posted by karls
I took 2 days to paint my bumper- laid it out on a trashcan and did one side then flipped it and painted the other side the next day. Seems like everyone likes the bedliner but I am disappointed that I went with it- and I even got "the one with real bits of kevlar in it"
Sent from my DROID4 using Tapatalk 4 Beta
Thanks for all the input guys. Why were you disappointed with the bed liner? I have debated between that or rustoleum textured paint but I would imagine the bedliner would be a little more durable than just a paint.
Old Jun 20, 2013 | 03:20 AM
Rooster76's Avatar
I have my grill sprayed with Rustoleum bedliner. It looks great. The thing I don't like about it is that it is very hard to clean unless you use a pressure washer. It's about like trying to wash 100 grit sand paper. I just ordered a ps bumper. I'm thinking of going with semi gloss.
Some people like the "hammered" paint. JCR has it as one of their recommended paint finishes. I would think anything textured would be harder to touch up seamlessly.
