Hard Time with Caster
Old Jan 25, 2010 | 06:03 AM
HarryHood1's Avatar
Default Hard Time with Caster
RIght now i am running 4" Tera flex springs with adjustable control arms up front. I am also running JE Reel front DS. My steering right now is still a liitle flighty, I am looking for a more stiffer feel in the wheel. Was wandering what some peoples measurements. Flightyness started with DS install. Also i was wandering who makes the Longest Adjustable Upper control arms
Old Jan 25, 2010 | 06:20 AM
codysanders's Avatar
i would say that if it happened with ds install they most likely had to set your caster lower to compensate for ds angle. unless you want to cut off your mounts and re weld new ones on in the correct spot you will probably have to live with it. you could try to turn your lca out a turn at a time until you get vibrations. then go back to setting before it vibrates. adjusting uppers may help as well. if you had it installed they won't take the time you will to dial it in correctly.
i speed read sorry. get a set of lowers and that will help some. spend some time adjusting yourself and you will get it to were you like it.
Old Jan 25, 2010 | 06:59 AM
spinlock's Avatar
Why do want the longest adjustable upper CAs?
If you want more Caster you would need shorter ones, however the pinion angle should set the limit.
