have 35's what suspension mods to go to 37's
Like the title says. I currently am running 35's with the following suspension mods.
Teraflex 2.5" budget boost
bilstein 5100 shocks (2-3.5" versions)
rough country 1.25" body lift.
jks front discos
poly performance front lca's that are 1/2" longer then stock.
What I want to know is what suspension mods do I need to do to clear 37's in the future?
jks front discos
The gussets are for axle strength not suspension. I already trimmed the rear wheel well pinch seam a little. I want to keep the stock flares.
My initial thought was to replace the 2.5" spacers with some 3" lift springs? That might get me the hight I need. Just not sure what else would have to be done with the springs..... ie drop brackets, adj track bars.....ect
JK Forum Regional Rep
jks front discos
jks front discos
ya I know there is axle work to be done....this thread is about suspension work to clear 37's
So the opinion is a 2.5" budget boost and 1.25" body lift should clear 37's?
Depending on how you are set up you may need another inch or so of bumpstop. I agree with the others to put the money in new rear axle shafts and proper gearing.
we'll for axles i was planning the following:
front:
G2 Core44 front axle (if they ever release it) with 5.13 gear, ARB locker, and Cro-Mo shafts....not sure what axle shaft splin count options there are 32,35? would like to get the biggest available for extra strength
rear:
ARB locker, 35spline Cro-Mo shafts and matching 5:13 gears
all this on a 2dr with 37's should be a formidable trail jeep?
front:
rear:
